International TLD: .com.br
Hi there!
I have already registered some “.com.br” domain names. If I buy a host package here and set the DNS1 and DNS2 in my registrar records, it should work, right? I mean, jodohost doesn’t work only with US TLD, I can have a “.com.br” or “.com.ar” TLD, right?
:slight_smile:
Emiliano.
Hi
Yes you can host any valid TLD
Hello Yash!
Man, you’re really fast! :slight_smile:
Thanks for your answer.
I came to jodohost because I saw the ad at webwizguide.
Regards,
Emiliano.
