I’m having some serious connectivity problems regarding any jodhost sites or utilites just checking to see whether its my local machine or not. I’m not having problems anywhere else except for jodos network
the problem includes connecting to my vps via rdp, cp.jodoserver.com is also unusable from my local computer
I was hoping someone from jodo could chime in here and give me an update…
No, there is no any ddos attack. We even checked from different location and all looks fine to us.
Yep, I’m having almost no response from Resellerdesk, and all my client CPs, as well as reseller CP. ![]()
may be an issue between australia and the U.S then, any other aussies having the same problem
I think it might be a network issue.. the route from here to Texas is terrible at the moment.
1 1 ms 1 ms 1 ms 192.168.2.1
2 16 ms 15 ms 15 ms nexthop.wa.iinet.net.au [203.215.5.243]
3 16 ms 15 ms 15 ms ae7.cr1.per1.on.ii.net [150.101.33.120]
4 69 ms 69 ms 106 ms ae3.br1.syd7.on.ii.net [150.101.33.30]
5 220 ms 222 ms 220 ms te0-1-1-2.br1.sjc2.on.ii.net [150.101.33.193]
6 * 257 ms 407 ms te13-1.br02.sjo01.pccwbtn.net [206.223.116.48]
7 * * 262 ms grande.TenGE10-2.br02.dal01.pccwbtn.net [63.218.23.126]
8 * * 259 ms xe-0-0-0-0.core01.gf01.dllstx.grandecom.net [24.155.121.82]
9 262 ms * 265 ms xe-0-0-1-0.aggr08.wacotx.grandecom.net [24.155.121.42]
10 * 266 ms * 24-155-191-116.static.grandenetworks.net [24.155.191.116]
11 265 ms * * 173.0.128.42
12 * * * Request timed out.
13 * 312 ms 295 ms cp.gohsphere.com [173.0.137.41]
Strangely enough, the forums are working fine. ![]()
Can you please check, what DNS is defined at your local work station.
Some time this can be a issue, please try to use Google public DNS i.e 8.8.8.8 and 8.8.4.4 and if this help.
Might still be something funky at Jodo. My client sites are a bit slow, but not too bad.
The CPs however are completely unresponsive. I can hardly get a response from any CPs or resellerdesk. Why is that?
Changed to Google DNS but no improvement.
3 15 ms 16 ms 15 ms ae7.cr1.per1.on.ii.net [150.101.33.120]
4 70 ms 69 ms 71 ms ae3.br1.syd7.on.ii.net [150.101.33.30]
5 221 ms 220 ms 220 ms te0-2-1-2.br1.sjc2.on.ii.net [150.101.33.147]
6 * 300 ms * te13-1.br02.sjo01.pccwbtn.net [206.223.116.48]
7 * 258 ms 257 ms grande.TenGE10-2.br02.dal01.pccwbtn.net [63.218.23.126]
8 * * * Request timed out.
9 260 ms * 265 ms xe-0-0-1-0.aggr08.wacotx.grandecom.net [24.155.121.42]
10 261 ms * * 24-155-191-116.static.grandenetworks.net [24.155.191.116]
11 266 ms 265 ms * 173.0.128.42
13 * 262 ms * cp.gohsphere.com [173.0.137.41]
14 290 ms * * cp.gohsphere.com [173.0.137.41]
15 * 263 ms * cp.gohsphere.com [173.0.137.41]
16 266 ms * 260 ms cp.gohsphere.com [173.0.137.41]
Things seem a bit better here but still chugging along a tad..
Antic What ISP are you using in Australia? I’m with internode
sorry antic
silly question I can see it’s iinet.. ![]()
There does seem to be an issue regionally there, we exchanged some mails about it.
I was actually away having a bit of a christmas party with some friends for two hours when the mails came I was about to leave to come check it but got with techs that said all sites look good outside.
Adding it all up, I got emails fine, on my mobile phone via 3g well outside our network, and the emails came quickly as well, so in the end, the connections were ok and working, but somewhere some packets are being dropped along the way, and it looks to start pretty early from what I see there on traceroute now.
After all the issues this last week I was just on a bit of panic mode on seeing that, and I know some of you may have been as well!
Thanks Stephen. Things seem to be a lot better now.
2 15 ms 15 ms 15 ms nexthop.wa.iinet.net.au [203.215.5.243]
3 * 15 ms 15 ms ae7.cr1.per1.on.ii.net [150.101.33.120]
4 73 ms 70 ms 68 ms ae3.br1.syd7.on.ii.net [150.101.33.30]
5 220 ms 220 ms 220 ms te0-2-1-2.br1.sjc2.on.ii.net [150.101.33.147]
6 251 ms 383 ms 265 ms te13-1.br02.sjo01.pccwbtn.net [206.223.116.48]
7 257 ms 259 ms 257 ms grande.TenGE10-2.br02.dal01.pccwbtn.net [63.218.23.126]
8 258 ms 258 ms 261 ms xe-0-0-0-0.core01.gf01.dllstx.grandecom.net [24.155.121.82]
9 260 ms 260 ms 264 ms xe-0-0-1-0.aggr08.wacotx.grandecom.net [24.155.121.42]
10 262 ms 262 ms 264 ms 24-155-191-116.static.grandenetworks.net [24.155.191.116]
11 264 ms 265 ms 260 ms 173.0.128.42
12 261 ms 265 ms 265 ms cp.gohsphere.com [173.0.137.41]
Now to resolve these damn Win33 site issues.. ![]()
