I need to display an ASP page inside a Flash movie. Is it possible to do this? We don’t want to leave the Flash environment and jump to another page. It would be impossible to implement the functions from the ASP page in Flash (I think).
Sorry, It’s not. What is normally done is place a flash file in an ASP. You can then control it initially by passing parameters in through the flash object tag. If you are feeling fancy, you can control your custom functions within your flash file with javascript and vice versa.
