I recently started noticing that everytime I attempt to open a javascript popup window from a page on my website, the Internet Explorer window freezes and never open. Is anyone experiencing the same problem?
I have a popup blocker that I have disabled and yet still cannot open any new javascript window on my computer.
problems like this appears after a while if you have changed settings in windows and installed lots of programs.. if possible, I would recommend you to reinstall windows..
I’ve seen this happen if you have more than one pop-up blocker installed. This situation happened to me exactly with my firewall, Zone Alarm Pro. I had Google blocking pop-ups and ZA blocking them as well. Check to see if your firewall is attempting to block them. Most firewalls have a setting saying something to the effect of “if the pop-up doesn’t load in XX seconds.” That may be the problem.
Or, you may have unintentionally downloaded something that is giving explorer a problem. Most likely a tracking window running under a generic svchost process. Run AdAware as well as Search & Destory to get rid of it.
Thanks for the response. I notice I get this problem on any webpage with a js window, once I click on a link which is not a full page but a js link.
I am thinking of reinstalling IE6 with SP2 pack. I dont know whether the problem was with my recent attempt to delete some applications I have not been using on my notebook pc for a while.
OR is there any where I can go in IE to reset my browser settings?
