Is there a decent document?
Is there a decent document describing how to use the vps with common things you might like to do?
just poking around in there, (all ssh as a terminal) it does not seem to do much.
thank you.
You might want to install a control panel to make things easer.I believe Jodohost will install webmin on request.
Kokr
Thank you Kokr!
that would make vps much more fun.
More info on vps : http://www.freevps.com/
You can get help on vps at http://forum.psoft.net/
Thankyou.
