Jmail Upgrade?
I’m trying to get a WebMail app working on my site (actually I’m trying 2, but they’re near enough identical…either the same people or “borrowed”);
http://www.xperior.co.za/Prod_XPeriorMail.asp
http://jmailbox.org/
However, when using them, it says that the version of Jmail that’s installed, isn’t supported.
I understand you run the Free version, which is fair enough, but on the second site it states that an older version will work - “You need either the PRO version or a PERSONAL version which was free before May 15th 2002 or any Version 4.2 or 4.1 - The current FREE version will NOT work.”
Also, on the first site it has the older, FREE version for download.
Would it be at all possible to test and maybe install this for people to use? It may help others who have run into problems because of the free version.
The link is;
http://www.xperior.co.za/sdaolnwod/w3JMail43Personal.zip
I’d completely understand if this isn’t possible though.
Kind Regards,
Oli Mortimer
