I am trying to get to JodoHost.com and it appears down??
Also, does JodoHost support ASP.NET MVC?
No jodohost.com is not down. We are here and working 24*7
Yes all new server support ASP.NET MVC.
We weren’t down at any point in the night ![]()
When such happens it is good to have this page bookmarked www.alertra.com then do the quick check in the top right, it will let you know if you are having ISP issues ![]()
I cannot access www.jodohost.com at all. I can ping and tracert it, but it won’t ever resolve in my browser…
Though I will say, on my iPhone it is resolving ![]()
I will check your IP you are posting from on the firewall there. I am about to join family for christmas celebration however, so it may be 6-8 hours before I am able to check.
on a normal day I’d already have it done before replying.
Thanks. Please let me know.
I’ve tried using TimeWarners DNS, Google’s DNS, and my standard OpenDNS and none are getting through to your site. Which then prevents me from looking at mine… I think I need an IIS setting changed, but can’t confirm until I see my control panel.
I am just about to leave but did do a check, it is working around the world otherwise so looks to be an ISP centric issue, if you send a ticket with the matter to us, maybe we can check it for you?
Timestamp Location Result Size Time
2009-12-25 10:49:29 EST Shanghai CHN OK 42.1 3.19
2009-12-25 10:49:29 EST Atlanta USA OK 42.1 0.17
2009-12-25 10:49:29 EST Chicago USA OK 42.1 0.21
2009-12-25 10:49:29 EST Orlando USA OK 42.1 0.23
2009-12-25 10:49:29 EST Las Vegas USA OK 42.1 0.45
2009-12-25 10:49:29 EST Oklahoma City USA OK 42.1 0.67
2009-12-25 10:49:29 EST London GBR OK 42.1 0.60
2009-12-25 10:49:29 EST Frankfurt DEU OK 42.1 0.83
2009-12-25 10:49:29 EST Hong Kong CHN OK 42.1 1.50
2009-12-25 10:49:29 EST Sydney AUS OK 42.1 1.53
2009-12-25 10:49:27 EST Frankfurt DEU OK 42.1 0.91
2009-12-25 10:49:26 EST Chicago USA OK 42.1 0.28
2009-12-25 10:49:23 EST Sydney AUS OK 42.1 1.53
2009-12-25 10:49:22 EST Atlanta USA OK 42.1 0.18
Understand… I SEE your IP, but when I get there… nothing is served up. A firewall problem (on your end) sounds like the idea problem. So from a simple ping and tracert check, your site is up from my box. But from actually viewing the site… no luck.
I’d love to submit a ticket… but I can’t get to the control panel.
I really need an IIS setting changed, to enable the page routing feature of ASP.NET MVC. IIS, by default, is set to check if a file exist and return a 404 error if it doesn’t.
I need that turned off:
Setting Application Mappings in IIS 6.0 | Microsoft Learn
i realize you can’t see the site for emails so here is a paste:
E-mail Support:
Although it is recommended that you use our ticket system, customers may also contact us for support on the following email addresses. These are directly fed into our ticket system and you’d be emailed back with a ticket confirmation email:
Windows or Linux Hosting, with
Date of Signup: Prior to June 23rd, 2007, and
Control Panel: https://cp.jodoshared.com
please email [email protected] for support
Reseller Hosting Customers, with
Control Panel: https://cp.m****here.biz
Windows, Linux or Reseller Hosting Customers, with
Date of Signup: After June 23rd, 2007, and
Control Panel: https://cp.g********.com
We can surely to the MVC setting, techs know how.
I am runnign late now got to get ASAP or they will be dining without me ![]()
Tickets opened.
MVC is already install on server. Also, i made configuration changes for your domain. Please check it now. It must full fill your requirement.
Also, i request you to always send us ticket from contact or billing mail address. Otherwise, we may not able to work on your issue due to authentication failure.
I wasn’t the only one late, family just got here as well ![]()
btw, you are not blocked on our side, but we cannot ping BACK to you.
