Joomla customization
I hope folks watch this forum!
I’m looking for two bids on what I think is a small Joomla customization.
Bid #1
At new account signup, the user will be prompted for an additional field, their member number (10 character alphanumeric). On submitting, the signup code needs to check a CSV file. If the number is present in the file, the account will be created. Additionally, the user’s contact information will be read from that file and user’s record in the DB populated with that information, including their member number. If the number is not present in the file, the account will not be created and a message will be shown to the user. That message needs to be customizable (I want to be able to edit it) though that text can be in a config/inc file and doesn’t have to be editable through the Joomla admin screens.
Bid #2
On member login, if the user is not an administrator-level user, the login code would check the CSV file by looking up the user based on his/her member number (pulled from Joomla db). If the member’s number is not present, they would not be allowed to log on. Instead, they would get a message, which again needs to be customizable (via a file edit is fine).
For both bids
This project will use the most current version of Joomla, which today is 1.5.4. This customization needs to be done so that future updates to the Joomla core software won’t overwrite and remove this functionality (unless that is not technically feasible). All code must be fully commented as to the modifications made. A list of changed, added, and deleted files must be provided. This does not need to be created as a module or component (unless that makes sense to do) and does not need a graphical installer option (I’m fine with uploading files, editing configs, etc. to implement the customizations).
I definitely need the functionality described under #1 above. The second part is nice-to-have and will be considered based on the cost.
Please contact me via PM to submit a bid or for further info.
Tim
