Kudos to JodoHost!!!
Seem like we only post here when we have a problem…well…I thought I’d thank everybody at JodoHost for the great work they have and ARE doing.
Everything is running GREAT…and I’m SO glad I moved over here (after trying a LOT of other hosting companies) over 5 years ago..might be longer, can’t remember…lol
Thank YOU!!!
z
Thanks :slight_smile:
We’ve had a few pimples of late but working on getting the zit remover cleanse treatment complete :smiley:
I’ll add my respects here too. With the CP problems today ( http://support.jodohost.com/showthread.php?t=23214 ) just want to say thanks for the regular updates, makes a lot of difference!
Your entire support team is incredible! I am consistently blown away with the level of support you guys provide and the constant communication provided in this forum. Your expertise is unmatched. Keep up the good work!
