Hello Stephen,
All our content links are not working at womensradio.com. We are getting perrmissions errors.X(
Here is an example: http://www.womensradio.com/content/templates/?a=3610&z=89
We did not change permissions.
Please fix this!
David
Hello Stephen,
Please fix this!
David
I’ve mentioned this to you before, but since you are not using the file prefix, you must have the directory indexes set it the index.asp or index.asp for that folder for it to serve anything.
In this case it looks you are using default.aspx, so that needs to be your directory index main page setup in Hsphere. It has changed names a few times over the years, and each time this has happened.
For example it works fine if you simply put this:
http://www.womensradio.com/content/templates/default.aspx?a=3610&z=89
Hello Stephen,
Your answer was the best and solved the issue. I wish the folks on the support side would have been so clear in providing the remedy.
We have absoultely no idea why the directory indexes changed
Veyr much appreciated!
David
