LiteHost Question
I am little confused here by this descr:
In LiteHost, you can host only upto 10 accounts of which 7 are free.
what do you mean account here?
If I have the plan now, but I host 8 domains under my user name, is it one account or 8 accounts?
A user account is a customer with a Hsphere control panel. Each control panel can host multiple domains.
So these are actually number of Hsphere Control Panels that comes free with a reseller plan. You can use additional CPs by paying $0.50/CP/Mon.
If all these domains are under a single user account, then it would be one account.
So let me re-phrase it.
Under liteHost plan, There are 7 free user account with separate control panel. extra account (or control panel ) will have extra fees.
But under each user account (control panel), it can host unlimited domains.
Am I right?
Absolutely correct …
