Logfile analysis problem
I’m trying to analyze my log files to check for some problems using software called Weblog Expert and am having some trouble – It says the files are not compatible. The odd thing is, I ran this same software on my log files some time back and it worked fine. I’m not sure why it no longer works.
It says it’s compatible with IIS and Apache logs – Is there a way to get my logfiles output to one of these formats?
Never mind – I found the problem (user error on my part)!
Just FYI the first line of the log has the format, you can in most analysis tools set the format manually.
