logging onto SQL Databases in EM
I have 2 clients - each have an SQL db on the same server - MSSQL7.
When i registered the first on EM -all fine. Now i cant register the 2nd, cos the server is already listed. But of course the 2nd database wont show, because i am logged in under the other clients username.
is there a way to have them both accessible - without having to change the login details each time for the server?
thanks!
We can allow one login access to both, but this may not work for you, so I woudl recommend using one registration in MS “named” based (ie mssql7.servicedomain.com) one IP based, that will take care of it :slight_smile:
good idea, Thanks Stephen!
