Looking for a Blog Module for DNN
Hey all,
I was just looking for a blog module for DNN 3.0. Any ideas?
NewBlog. works GREAT
http://www.dnnportal.de/Default.aspx/tabid/176
(it’s page on dotnetnuke.com http://www.dotnetnuke.com/default.aspx?tabid=794&type=comm&site=138&parentid=42 )
the author’s site is mostly in german, just scroll down on that first link and you’ll see it NewBlog Version 3.0.0 Final Release ¶
hope this helps!
You CAN get .Text integrated into DNN 2.1.2 - it’s not pretty and it’s not fun but .Text is a really good blog. I personally use <yBlog from http://dnn.trefry.net/ - it’s easy to get into DNN and it’s functional.
functionally, the NewBlog and MyBlog look exactly the same… i’m wondering if one isnt a rip of the other… i doubt it, but it’s worth checking them both out
[QUOTE=Bobum]
Where did it go? The page is blank when clicking on this link.
[QUOTE=rwholmes]
Looks like he switched froim using DNN to using Community Server and took it down. See if it’s over at SnowCovered.com
Re: Looking for a Blog Module for VBulletin 3.0.8
hi there i am hosting one one of the foums with vbulletin 3.0.8. but nw i would like to add blog option to the same.. Is der any direct way or could u provide an option which i could add to forums dat blogs can be used by users.. Preferences of blogs which are compatible to vbulletin 3.0.8
You can check Coding Staff dnn blog module. Pretty sleek extension with AJAX interface and bunch of features. You can even embed other modules inside of it.
