If you find yourself stuck with your code and you are in search of some sites from where you could get some help try out the following links you might get what you are looking for:
Java Scripts
http://www.a1javascripts.com/
http://www.javascriptcity.com/scripts/
http://www.java-scripts.net/
http://webdeveloper.earthweb.com/webjs/
http://www.javascriptkit.com/cutpastejava.shtml
http://www.javafile.com/
http://javascript.com/
http://javascript.internet.com/
http://www.j-scripts.com/
http://devedge.netscape.com
http://www.htmlgoodies.com/primers/jsp/
It’s not a good idea to promote yourself at your competitor’s forum
Yash, I thought that was pretty cheezy, too.
