Srs. Jodohost,
I?m having problems with the session state in asp. The application is losing the state after 1 or 2 minutes of work on any user despite the ?Session.Timeout? is set to 10 minutes. I?m sure that the problem isn?t in the application because in the development environment all works well.
Thanks for your help, it?s urgent.
