do you have Magick Wand installed?
http://imagemagick.org/script/api.php?#php
It is an extension to the Image Magick for PHP.
If it isnt installed, would you consider installing it?
has anyone worked with animated gifs and image magick?
What server would you need it on?
it be web.jodoshared…
I will speak with the unix manager and see if this can be done.
thanks
ImageMagick includes MagickWand and is already installed on this server.
Let us know if you find any problem using it.
oooo neat.. thank you
are you sure you have image magick running and working?
i cannot get any scripts.. even very simple ones (just inputting and then outputting the same image…) to work at all.
thanks!
nevermind on this.. gd will work fine for now..
cant wait till they add gif animation!
