Mail5 cl2 down - power supply for sure bad
It just went down, I was in the datacenter working another row and heard a pop. Turned around couldn’t see any issue but checked and found this node down. I know the power supply module for sure is bad, I am hoping not any worse than that.
OK, power supply it was, I actually had to wait about 8 minutes even to pull it out, it was VERY hot. It has a massive failure by the look and smell of it, but the server has turned back on and the RAID is showing to be in good shape. I expect we will have a fsck however as it was a very rough and abrupt shutdown. This will be 15-20 minutes time and then should return to up if all goes well.
The server has been up for about 10-12 minutes now, just working to check it all out and make sure it’s complete good after that bad shutdown.
