Mambo write permissions
Just installed Mambo from the Easy Apps in the control pannel. I am playing around with cofiguring the CMS. However, I can’t seem to write to any directories on the server. Do I need to make a change within the H sphere control pannel to get this to work? My FTP logins and passwords are the same as those for my mambo superadminstator.
Thanks for your help.
MS
You’ll need to use an FTP program to connect to your web/ftp server and set filesystem permissions. There’s some info here http://forum.mamboserver.com/showthread.php?t=58455 and you can find more with a quick Google.
Tim
