I have a site setup and working fine.
www.(sitename).com
can anyone point me in the direction of how to add a 2nd domain name to the same account, pointing to the same place
ie. www.(sitename).co.uk
thanks
www.(sitename).com
thanks
Thanks for that, however, I should have given slightly more information.
It is a windows reseller account that I have
That link is to the end user panel, so make sure in the plan you have for the end user account that you have domain aliases enabled and then the directions are the same.
Thanks, got it now.
Yay
