is it posiible to have more than 1 ftp users with different rights?
thanks
manos
thanks
manos
Yes, it is possible ![]()
If you are using Windows plan than you can ask JodoHost support to create it for you and if you are using Linux Plan than you can yourself do it from your control Panel.
Thanks for immediate response
Is it possible this account to ahve access only to one domain (directory) of the total plan?
best regards
manos
[QUOTE=Gurmeet]
Yes it is possible.
Already created account by support
many thanks
manos
[QUOTE=Gurmeet]
Yes it is possible.
You are most welcome. :]
