So here is my whole output (with my values taken out)
# Movable Type uses the CGIPath setting to construct links back to
# CGI scripts; for example, the MT tag <$MTCGIPath$> is substituted
# with the value of the CGIPath setting. You will need to change this
# value when you first install MT; instructions for doing so are in
# the Installation Instructions, in INSTALLING THE MOVABLE TYPE
# APPLICATION CODE, Step 3.
CGIPath http://www.gamecubecheats.info/mt
ObjectDriver DBI::mysql
DBHost mysql.jodoshared.com
DBPort 3306
Database [my database name]
DBUser [my database username]
# The filesystem path to the 'db' directory, where your MT database
# files are stored. You will probably need to change this when you
# first install MT; instructions for doing so are in the Installation
# Instructions, in INSTALLING THE MOVABLE TYPE APPLICATION CODE, Step 8.
DataSource mysql.jodoshared.com
