Moving asp sites
I need to move a couple asp sites from a host that went out of business but I don’t know anything about asp hosting.
Do I need to determine which version of asp the sites are currently running or what will that affect?
I downloaded the files from the other host and am uploading them here. They interact with some sort of sharepoint in-house server but is it possible they may work just fine after the domain name propagates and is pointing here?
I guess I will find out soon and ask some questions if the site don’t work.
thanks!
-George
if they are just ending in .asp then there is no need for version info. If they are .aspx you need to find if 1.1/2.0 version
I’m good then, thanks for the quick reply!
-George
