Can your ms sql servers be accessed using ms sql enterprise manager. I would like to do this because of the tools that are availabe with this setup.
also how many sql db’s do you get with the Gold plan.
Ren
Ren
Yes you can use enterprise manager.
You get 3 databases (MS SQL) and size is up to your disk quota
