i;m having a sudden issue with an MSSQL login on mssql5.
is something up?
is something up?
It is working for all the sites I know using it and being quite fast too
submitted an urgent ticket a few mins ago with the details
this is a site that been running smoothly for months
Can you tell me which ticket number?
I am not finding a ticket from you regarding mssql5.
good catch - i didnt receive a response
how can i send to be sure it will be received?
just mail to me for now, my name at jodohost
it seems the ticket system is rejecting some mail with a bounce, Deepak is checking it now.
yep, i didnt get a response either from sending from another email either/
just sent it to stephen.XXXXX at jodo
it came in there was an issue with the ticket system for a little while, one client mailed us an error and we resolved.
Your ticket is resolved too.
thanks.
what was the sql issue?
pity about the mail issue - it caused the sql issue a 90 minute delay in resolving…
The database moved to a suspect state do to some errors from the previous server, I was able to repair and restore it for you.
there were about 11 DBs that kept saying suspect status on the old server, this was one of them, and the reason we moved servers.
ok, thanks.
glad its not suspect anymore ![]()
