MSSQL5 slow - resolved
A user is utilizing 100% of CPU on MSSQL5, I am checking on this and will be notifying the user of the problem as soon as rectified for others.
Re: MSSQL5 slow - chcking it
I have found the databse but going to have to restart SQL services on MSSQL5 to fix the issue in the fastest manner.
Issue corrected, most databases are re-attached after the restart, you may get login failed errors for the next 1-2 minutes if yours is not yet attached.
After checking the logs there was a database that had a problem, that database has been corrected and MSSQL5 is running better now.
