msxmlsql.dll
I just installed a module in Dotnetnuke (xMod) that requires the file msxmlsql.dll (XML processor for SQL server).
My DB is on winsd1. Could you please check if this file is installed. Please look at this kb for further information.
Programs may fail when you remove an instance of SQL Server 2000, MSDE 2000, or SQL Server 2000 Desktop Engine (Windows)
Jean
Any news on this issue? I have been waiting one week for a resolution and I need to make alternative plans if this issue cannot be solved.
Jean
Hello,
I have been made aware of this, but have been quite busy with the server moves, I am checking on it now.
This file is available now, let me know if it does not work, I may have to restart the SQL services.
It works like a charm. Thanks Stephen and good luck with the rest of the move…
Jean
