I am getting this error
Your message did not reach some or all of the intended recipients.
Subject: test mail
Sent: 24/04/2004 22:18
The following recipient(s) could not be reached:
'[email protected]' on 24/04/2004 22:18
553 sorry, that domain isn't allowed to be relayed thru this MTA (#5.7.1)
Can someone explain to me what its all about Ive had a look threw the forum and i am a little lost. Ive set up the required changes on the outgoing mail server in outlook and all things worked well had no problems until today…
Which required changes are you referring to?
Do you have SMTP authentication enabled?
yep i enabled that a few days ago sortd it out when i got the email.
I think i sorted it !
outlook was set to use the same settings as the incomming server so ive clicked on the other box thats says logon using :
it has the 2 input boxes for user name & password.
now its working again not sure why?
In Outlook, you just have to make sure it doesn’t say to login to Incoming POP3 first. Use the same settings as your incoming server.
This was a change JH made in the last week, so you’re not going crazy.
