My IIS does not execute ASP pages with C# Code
I recently posted a problem with C# code, and I finally discovered that the problem is that my IIS is not recognizing C# code, and therefore, does not execute anything between the <% %> delimiters.
What should I do? Do I reinstall .NET on my computer?
Help! ?(
Make sure the .Net Framework is installed on your PC.
-Dave
are you talking about ASP or ASP.Net?
i dont think .Net languages will work in Classic ASP…
Try reinstalling IIS…
[QUOTE=alejandrormz]
Help! ?(
