is there any advantage of offering mysql plans?
does this use the same shared db as other mysql, or does it set up an independant db for that plan?
It’s the same database server. No technical advantage.
Ok,
I see It does not have any web service activated, is there any way I could do a MSSQL plan like this? As I see a lot of other web hosts do not even do MSSQL (especially free ones), so a MSSQL only plan could be ideal for these.
Could you create a MSSQL Plan wizard to do this?
Anthony
Yes, you can create a MS SQL only plan. However if you create a Cold Fusion plan, it will also require MS SQL.
You can get some idea regarding what could be useful to customers from JodoHost’s shared hosting plans.
How would you do a MS SQL only plan (like mysql with no web services/email) as there is no MS SQL Plan wizard, if I use windows plan wizard i still get all the web services.
