My phpbb forum has stopped working! Is this a jodohost problem?
[CODE]phpBB : Critical Error
Could not connect to the database [/CODE]
this forum runs from the same MySQL server. How are you connecting?
I’ve got to be honest with you, it’s been so long since I looked at the MySQL settings that I can’t remember! And now that it’s down, I can’t get into it to look at the settings within phpbb. It’s been running with the same setting since I joined and set it up though.
Can you submit a ticket please, will ensure its looked into right away
Will do - Thanks.
