[code=DNS_HOST_NOT_FOUND] The host name was not found during the DNS lookup. Contact your system administrator if the problem is not found by retrying the URL.
those nameservers are not typically customer facing and may report that they are invalid as they are not the NS record on record for the domain. You need to use the ns3/4.yourservicedomain.com
You need to first register your name servers at GoDaddy before using it as name server. I think you can do the same in the “Host Summary” section of GoDaddy control panel.
Guess what? Another person is the owner of this domain And when I contacted your support to change my main domain they told me that it is VERY difficult to do without deleting all the files and sites there…
What do you mean another person owns the domain? Are you referring to: hishamsite.com
I just checked the whois, and it is registered to:
–removed for confidentialality –
the DNS is ns3/4.m****here.biz which sounds like the settings you used (definitely JODO settings).
You are right, it is hard to switch your reseller account (I had to do that about 6 months ago).
If hishamsite.com is just a subaccount for you, I would delete whatever you have on it at Jodo, then recreate the account. But, like mentioned above, you need to change your nameservers to your own: ns3.moieu.ws and ns4.moieu.ws (assuming that is your reseller acct).
