I don’t have a user level DB on mssql11 to test full function of the web backup interface.
Can you please go to:
http://mssql11.jodoshared.com/mssql
(or if a reseller use your own url for mssql11 with a /mssql on end)
I’d like to ensure backups take properly before saying it is ready. MSSQL12 will be ‘ready’ for a test shortly.
Re: Need a favor from MSSQL11 (and soon 12 customer)
and 12 is done now as well.
Hey Stephen,
Did you mention a size limit on the DB when using these tools?
Cheers,
Paul.
Well the web.config goes like this:
<httpRuntime
executionTimeout="1900"
maxRequestLength="2024000"
useFullyQualifiedRedirectUrl="false"
minFreeThreads="8"
minLocalRequestFreeThreads="4"
appRequestQueueLimit="400" />
That is very near the max allowed of the maxrequestlength
I’ve seen issues on DBs over 50MB many times.
If you have one larger and a fast net connection, try it out and let me know
We’ve tested now on a 40ish MB on mssql11 successfully, and 8MB on MSSQL12.
We’ll probably start giving it as the first choice in backups on tickets, if there are problems we’ll provide manually.
