.NET4 and MVC 3
Do the Windows servers in cluster 1 support .NET 4 with MVC 3 and the RAZOR view engine?
Not all of them, most of the migrated servers do, a couple of the earliest migrations don’t/didn’t but the rest do.
(all have 4.0 but MVC 3 no)
Is there a plan to support MVC 3?
thanks,
-brit
MVC3 is already on a number of CL2 and migrated CL1 servers. If you can give me a server I can check it, we are putting it on any new migrations as well.
Win34
thanks,
-brit
It had an error in installation, I’’ see if I can get it resolved this weekend.
Great. Thanks, Stephen.
finally got the bug tracked down and installed, and notated it for google to index for other as well.
Thanks, Stephen. I appreciate you pulling this off for us.
-b
hi, does win6 have mvc3 support? I copied bin and views folder and global.asax, web.config files, but the site does not seem to work?
Win6 CL1 and CL2 should both have MVC3 support.
