Network issue resolved
There seems to be a provider side network issue and all our subnets are unreachable at the moment. We are looking into it and will post an update soon.
Re: Network issue
Network is up. We are now investigating the root cause.
Re: Network issue
the router rebooted, this happened some time after the FCP was activated. They are disabling the FCP from the network to prevent this from happening furhter.
Re: Network issue
the FCP has been disabled, and there should be no further problems.
