How can I subscribe to Announcement & outages forum.
2.My ns 1,2,3, & 4 are set to my .com.au domain, this helps AU customers down here for search engine AU results. I also have the .com version of my domain using as an alias of the .com.au, is it possible to allow my non au customers to set thier nameservers to the ns .com domain as an option somehow? How?
I’m thinkink my US customers would be treated better with se’s if they were on ns1.mydomain.com.
you cant acctually subscrible to the announcments forum - there was a reason for this, i think it was that it gets updated so much that they’d be sending to many out
they also said that any important announcments are sent by email anyway so you dont really need to
you set it up just like the .com.au
go to your registrar and add the IPs to the Child Name Servers (i think it is)
then in HSphere add the IPs as DNS Zones i think its A Records
That’s not the reason, Stephen was supposed to look into it. It seems to be a vB problem. It works fine on other vB installs.
Yes,I was looking into it, but could not find the reason, I am going to upgrade, Yash lost some of his emails in an outlook crash, and is looking for the email from jelsoft, I need to remind him
