Microsoft OLE DB Provider for ODBC Drivers error ‘80040e4d’
[Microsoft][ODBC Microsoft Access Driver] Too many client tasks.
file.asp, line 3
support told is because i have not created any dsn for the database.
common sense tells me that i don’t need a dsn for a dsnLes connection… or i’m i missing something?
someone on the server is not closing their connections and we are left with error messages… is like sharing your apt with somene who won’t flush the toilet. it sucks!
[QUOTE=marioletto]
This issue is caused by the Access ODBC driver. it the the most unreliable driver you can use on a shared hosting environement
Although we fixed it, we cannot guarantee this error will not occur again. Please use Jet OLEDB instead as it has better connection pooling and handling. microsoft strong discourages using Microsoft Access ODBC driver as well
Thanks for fixing the problem Yash… i recieved your email and read this post http://support.jodohost.com/showthread.php?t=3146
the only problem with this is that your ODBC Service in Hsphere does not have a jet option??? i use access DB’s for sites that gets modified alot
I like MS SQL alot its just alot more work to use it…
So if you can add a jet set up in the ODBC Service ill change ASAP
