I currently have a ValueHost reseller account. How do I begin (and create) offering Web hosting plans that have ColdFusion MX support (like, how can I make signups go to WinCF instead of Winx?). Do I just simply create a new plan that has ColdFusion support turned on (and the rest turned off)?
On the CF plan you create, ensure ColdFusion resource is enabled and then the plan is configured to the ColdFusion Servers group
Thanks, Yash!
