Open cart issues after going live
Hi, I don’t know if you can help me with this Stephen, but it’s worth a try.
I installed opencart on earapearrings.com. I was testing it on the IP address because the site wasn’t live. Got the store set up and tested fine.
Saturday I changed the DNS to point to the IP address so the site would be live. I changed 2 config files to have the correct path of the domain name instead of the IP address. Everything seemed fine.
But the CKeditor is all screwed up. It appears fine, I can make changes, add an image, etc. but when I save it and view it from the front end there are all sorts of weird characters - like “/” instead of an image. Font colors or bolding does not show up.
I’ve checked my folder permissions and they are as they should be. Do you have any clues why it would stop working correctly after changing the DNS? I keep thinking I must have overlooked some little thing.
Thanks for any help.
It has been resolved via ticket…correct?
Re: Open cart issues after going live - SOLVED
Yes, you resetting the magic quotes fixed the problem.
Thank you!
