osCommerce Upgrade
The upgrade feature in the hshere control panel seems to be a little buggy. It duplicates configuration settings, apparently in the database. Does anyone know how to successfully upgrade osCommerce on JodoHost’s network?
[QUOTE=jhunnicut]
A client of mine is having problems with this as well. And there are not any modules installed (i.e., payment modules like php/authorize.net/etc). Anyone know what’s the word with this?
Did you recently installed OScommerce? If yes, then the upgrade feature is not for you and can create duplicate entries.
I just installed OScommerce on a test site (on a winbox) and installed paypal from admin interface. It worked fine for me.
Thanks, Tanmaya. I did recently install osCommerce. Does that mean I already have the latest non-beta version (v 2.2)?
If so, I would like to make to UI recommendations. First, if we don’t need the upgrade, remove the upgrade icon. Second, make the version number visible on the h-sphere control panel under osCommerce.
It may also be prudent to update the help screens at:
Creating an Online Store - H-Sphere User Menu Based Guide - Positive Software Corporation
  • jim… :slight_smile:
Jim, we will submit the ideas to psoft about the version number and upgrade icons.
If you’re at all serious about implementing osCommerce, download the files from www.osCommerce.com and do a manual install.
osCommerce 2.2 MS2 release date is july 12 2003 and it is the latest version (except CVS). Upgrade is only for people running osc 2.1 as i know.
