Path changed!
In my aspx files, I had to use absolute path to access databases. Suddenly they are broken as the path seems to have changed. The path to my base was C:\hshome. What is the new path?
Thanks.
The new path is d:\hshome
We always recommend relative pathing instead of hard pathing
But I checked that script. It has relative path: /hshome/…
Still it is broken. Any ideas?
Thanks.
There is some serious problem. I created a new script to test and it gives 404 even after uploading to the server. Are you sure Ftp login is going to d:? I am sending you a separate email giving exact location.
everything is right here Sanjay:
http://support.jodohost.com/showthread.php?p=13406#post13406
Sorry for the inconvenience
I got it. The ftp was one problem. In future, please email notices of such changes as it is by chance that I got to use that script.
Also, in spite of using relative path “/hshome/” it was substituting “C:” there. This might be an IIS bug? There is no way I can substitute server.mappath() in the ConnectionString. This seems to be a limitation of the ASP script. If anybody knows the answer, please let me know.
Thanks for the quick support!
The email is my fault, I had it prepared but had worked 8 hours solid, and took a break, I forgot to do it when I sat back down, I will go ahead and do that now.
I am running into a similar issue… I have FTP’d into the server like you said and the files I am looking for are there, but my DNN app says I am still on the C drive? What gives?
DNN should not be hard coded to c:, you need to make it relative, or set it to d:\ manually. All servers here now have the user data on d:\
It’s totally all relative on my site and my site has been down all day… X(
coldfusionman, your site is on win2 so this win1 migration had nothing to do with your website
I suggest you re-check your configuration and open a ticket if there are any problems
