I WAS using
#!/usr/bin/perl
Is that the correct first line?
I WAS using
#!/usr/bin/perl
Also what are the permissions for writing to a data file. Is it just User write, or does Group and other also have to have write checked…Thx, z
Yes, that is correct for unix, windows ignores that line, so it is not required.
Thanks Stephen…was debugging a counting script that used to work…turns out I had to reset my permissions on the executable to 755…btw, user is the web user calling the script through html, but what is Group and other?..Thx, z
I am not much on unix these days,but 777 will for sure work, 755 SHOULD work.
Ok, thanks…z
