PCS4 node - 3 VMs - urgent maintenance.
There is no issue on the server itself or the VMs but we have found it is causing some issues for other nodes due to it having a NIC that is mega broadcasting into the network and making some other machines not working right. This maintenance should last less than 15 minutes as we have to physically move some cables and ports around on the server and it can’t be done live.
Well maybe it is something more..because the node is not returning to power on after being down.
Note that this is a rebuild PCS4 not the same as the prior posts/issues on PCS4, but it was rebuild using some of the same parts.
