PDFlib installed?
Is the PDFLib PHP component installed on wincf?
Tim
Don’t believe it is, but using a custom php.ini you can drop the extension in and make it work :slight_smile:
Thanks Stephen. From the docs, I thought this component had to be enabled at PHP install time. I might try the R&OS PDF classes ( http://www.ros.co.nz/pdf/ ) first before I go for installing PDFlib. Their classes seem a bit easier to use.
Tim
