Persits.Upload
I moved a site here that has a script to upload photos to a real estate site.
But I need to change something to correct the following error:
[CODE]D:\hshome\alcadmin\arizonarenttoown.com\admin\PIC_Upload.asp
Persits.Upload.1 error ‘800a0028’
This feature has been disabled by system administrator. Use File.SaveAsVirtual instead.
/admin/PIC_Upload.asp, line 25 [/CODE]
Its something to do with this but I don’t know how to correct: AspUpload.com -- UploadManager Object
If I paste part of the code to my script could someone help me out if it is a simple fix?
Thanks! Code below:
line 25 would be: File.SaveAs Path & "" & Answer
[CODE]Set Upload = Server.CreateObject(“Persits.Upload”)
'On Error Resume Next
’ we use memory uploads, so we must limit file size
Upload.SetMaxSize 1048576, True ’ Limit files to 1MB
’ Save to memory. Path parameter is omitted
Upload.Save
txtID = Upload.Form(“homeID”)
txtPicture = Upload.Form(“txtPicture”)
txtPicNum = Upload.Form(“txtPictureNum”)
txtProp = Upload.Form(“txtProperty”)
Response.write(Server.MapPath(“PIC_Upload.asp”))
Path = “D:\hshome\alcadmin\arizonarenttoown.com\admin\properties”
Upload.OverwriteFiles = True
’ Save files to it. Our form has only one file item
’ but this code is generic.
For Each File in Upload.Files
Answer = txtPicNum & “_” & txtID & RIGHT(File.FileName, 4)
’ Database Open[/CODE]
Hi
You may not need to use saveasvirtual option as you are using save to memory option.
Try the code below.
Cheers
Yogesh
'Path = “D:\hshome\alcadmin\arizonarenttoown.com\admin\properties”
Path = “/admin/properties”
’ File.SaveAs Path & "" & Answer
File.SaveAs Path & “/” & Answer
’ Database Open
Thanks Ryogi
I tried that and I get the same error.
Hi
Sorry for that. U’ll have to use virtual. Below code is tested and works. Plz try and let me know.
U will have to create a subdirectory “upload” under the folder where u run this script.
Cheers
Yogesh
Upload.OverwriteFiles = False
’ On Error Resume Next
Upload.SetMaxSize 100000, True
Upload.Save
Set File = Upload.Files(“FILE1”)
If Not File Is Nothing Then
’ Obtain file name
Filename = file.Filename
’ check if file exists in c:\upload under this name
If Upload.FileExists(“upload/” & filename ) Then
Response.Write “File with this name already exists.”
Else
’ otherwise save file
File.SaveAsVirtual “upload/” & File.Filename
Response.Write "File saved as " & File.Path
End If
Else ’ file not selected
Response.Write “File not selected.”
End If
Sorry for so many questions, but here is my original code, do I omit what you didn’t include in your example or ?
Thanks for the help!!!
[CODE]<%@ LANGUAGE=VBSCRIPT %>
<%response.buffer = TRUE%>
Upload.Save
'File.SaveAs Path & "" & Answer
'Database Open
Set oConn = Server.CreateObject("ADODB.Connection")
oConn.Open "Driver={MySQL ODBC 3.51 Driver}; Server=mysql1.g********.com; Database=alcadmi_main; UID=admin; PWD=******; Option=3"
	sSQL = "UPDATE rent_homes " & _
	"SET Picture" & txtPicNum &" = '" & Answer & "' WHERE homeID=" & txtID & ";"
	oConn.Execute sSQL
		If Err.Number = 0 Then
		   Session("strErrorID_result") = "Success: "
		   Session("strErrorDescription_result") = UCASE(Answer) & " was updated."
	oConn.Close
	Set oConn = Nothing
			   Response.Redirect("property_edit.asp?homeID=" & txtID)
		Else
		Session("strErrorID_result") = Err.Number
		Session("strErrorDescription_result") = Err.Description
							oConn.Close
							Set oConn = Nothing
		End If
Next
%>[/CODE]
I am ok to answer the questions as far as I understand them, so plz feel free to post your Qs untill it gets resolved.:slight_smile:
Ok here is the exact snippet where you need to change (* plz note the SaveAsVirtual) -
Existing -
'Database Open
Change To
File.SaveAsVirtual Path & “/” & Answer
'Database Open
Rest all remains same. Hope it helps.
Cheers
Yogi
Ok I created the upload subdirectory.
Now I get:
Save method must not be called more than once.
/admin/PIC_Upload.asp, line 22
Line 22 is:
Upload.Save
Just our of curiosity I tried removing that line and the script appears to work without errors but the file was not actually uploaded.
You had asked that I create a folder upload under the directory of the script but I was already using a folder properties that referenced in the path statement.
So I changed:
and
to
If Upload.FileExists(“properties/” & filename ) Then
and
File.SaveAsVirtual “properties/” & File.Filename
That seems to work and I can upload photos now.
But, if I go back to edit or change and existing photo the photo will not change and I see filenames like:
But maybe it had that problem before I moved to this server, not sure, I just took over the website.
Thanks for the help Yogi !!
My pleasure George
Good to know that the upload is working now.
BTW while exchanging messages I put the following line in the code -
Which earlier was
So whenever there is existing file with same name as file being uploaded then the new file will be created with some extension.
So you are getting it -
You may turn this feature ON/OFF by setting True or False depending on your requirement. But better to keep it False as there is always a chance that users will use very generic names for their images. like house.jpg, James.jpg etc. So one user can overwrite the other users pic.
Wish u good luck in your project.
I am into SEM and SEO. If have any requirements for your site or your client’s site plz IM me.
Cheers
Yogi
The way it was working before is that when you up load a pic it changes the names of the pics to
1_57
2_57
3_57
Its a real estate site so when you edit a listing it adds the id number for that property and just puts 1,2,3 etc in front.
I will play with it and figure it out and will email you about some other work.
thanks!
-George
