photo rating
hi guys,
if u can intrest with my new site http://www.desihotornot.com
just u can post u r photo ,that is rated bt others.
thanks
may I make a couple suggestions. Try running your site at a higher resolution (my res’s are 1680x1050 and 1600x1200, both are messed up).
Also, take off the stretching of the images, it makes the people look scary. You’d be better off checking the height and width of the image and then scaling the larger size down to the appropriate pixels while retaining the proper aspect ratio.
thank you very much
My clockwork computer won’t reach such high resolutions so the site looks fine at 1024x768. Even so, the guys still look very scary - I wouldn’t want to make adverse comments about them!!!
Looked at your Classified Ads site too - very colourful but possible a bit too “busy”. So much going on it could be quite easy to miss a crucial advert.
thank you very much,
pls pass this site http://www.desihotornot.com
to your friends ,i.e help ful for me,because every on have an on idea,pls help me…
mahipalreddy
hi there… you’ve got quite a site in there though i think it’s a bit crowded… full of texts though… posting a pic??? hmmm lemme see… maybe i will… :slight_smile:
