PHP Info
Is there a URL where I can go and see the current phpinfo(); for JodoHost’s server?
(reseller account, *nix platform.)
tia,
  • james
here
[QUOTE=SubSpace]
here
Thanks for the prompt resonse!
What are the chances that JodoHost will increase upload_max_filesize to 8 MB?
thanks again,
  • james
Can’t say, you’d have to wait for someone at JodoHost to comment on this.
Personally I think that if you need to upload 8MB, there’s probably a better way than some webform :slight_smile:
[QUOTE=SubSpace]
I hear ya, but one of my clients is an attorney that digs the little browser-based Case File management tool I built him.
Unfortunately, the current hosting situation also has a max upload of 2MB and he’s tired of splitting PDFs into 2MB chunks.
Hmm, well if you’re looking to take a reseller account, you could set up a VPS account under it, install Apache and PHP and use whatever settings you wish.
Would cost you 500 MB of diskspace to set up the VPS though, and there are memory and process limits on the VPS even though I don’t quite understand how they work..
Anyway, it would be relatively expensive, but ease of use comes at a price, right? :wink:
