Physical path on wincf servers
What is the physical path on wincf?
Is it d:\home\ftp-login as shown in my reseller panel or is it something else?
I’m struggling to get a script working that requires this parameter and nothing I enter seems to work.
Tim
Ah, it is E:\ on the CF server, don’t know why it shows d:\ in the control panel, but the control panel paths are rarely ever correct.
And it is e:\hshome\username\domain
(other servers with some exceptions, are d:\hshome\user\domain)
You can always get your path by putting a test script in the root of your site that has this CF snippet:
#ExpandPath("./")#
[QUOTE=LevelHosting]
#ExpandPath("./")# [/QUOTE]
I should have thought of that! (I guess I was stuck in PHP mode because the app I’m trying to install happens to be PHP-based.)
Thanks to both of you.
Tim
Well than use php…
<? phpinfo(); ?>
:stuck_out_tongue:
