I currently use the aspSmartUpload.SmartUpload object so that my site visitors can upload their holiday snaps into my site gallery. I permit a max size of 30k per picture. Some members have problems resizing pictures. Is there a way of letting them upload a pic of any size (within reason) and then resizing then via the script before saving them to the server? I currently use the following code:
(Any advice very welcome - thanks.)
On Error Resume Next
’ Variables
Dim mySmartUpload
Dim intCount
’ Object creation
Set mySmartUpload = Server.CreateObject(“aspSmartUpload.SmartUpload”)
’ Only allow txt or htm files
mySmartUpload.AllowedFilesList = “jpg”
’ DeniedFilesList can also be used :
’ Allow all files except exe, bat and asp
’ mySmartUpload.DeniedFilesList = “exe,bat,asp”
’ Deny physical path
mySmartUpload.DenyPhysicalPath = True
’ Only allow files smaller than 50000 bytes
mySmartUpload.MaxFileSize = 40000
’ Deny upload if the total fila size is greater than 200000 bytes
mySmartUpload.TotalMaxFileSize = 200000
’ Upload
mySmartUpload.Upload
’ Save the files with their original names in a virtual path of the web server
intCount = mySmartUpload.Save(“/gallery/your holiday snaps/uploaded”)
’ sample with a physical path
’ intCount = mySmartUpload.Save("c:\temp")
’ Trap errors
If Err Then
Response.Write(“Incorrect File Type - Only JPG please : ” & Err.description)
Else
’ Display the number of files uploaded
