Hi Yash,
Thanks for your answers
- Yes, leave the the max field and pricing field emtpy for that feature
Ok
- DB users are the number of users that can access a database. Each DB user (in MSSQL) requires a MS SQL login. I could be wrong because I’m not well versed with MSSQL. But I’ll ask our db admin and tell you. Our configuration allows unlimited logins and users.
I want to configure the plan so the customer can have 1 MSSQL DB, 1 MYSQL DB, 1 PGSQL DB. What values should have:
[ul]
[li]MS SQL Login, MS SQL Database and MS SQL Database User
[/li][li]MySQL Database , MySQL User
[/li][li]PGSQL Database , PGSQL User
[/li][/ul]
These fields can be confusing. For example, if I put 1 in the “MS SQL Database” field and leave both “MS SQL Login” and “MS SQL Database user” blank (as you did): What will happen? The DB will be created and the customer will not be able to login? (the same question is valid for MYSQL and PGSQL)
- How do you have access to our plans?
I do not have access
, just Mr Atul did me a favor regarding my first plan.
Credit basically allows customers to buy additional features without paying immediately. Once their debt exceeds the credit limit, they can’t add new features unless they pay. You can also configure HSphere to warn/suspend customers who have exceeded their credit
Sir, I am still confused here
The current value for “credit limit” is 5. What does that number mean? It does not seem to be a dollar amount, then what exactly is it?
- What you are looking for is a hard limit. if you leave that field blank, customers could buy additional resources for free. So don’t do that! Instead, once you have created the plan, click the settings button next to the plan name. It would allow you to set a hard limit for resources. You can even create billing periods from there
Ok, thanks!
- There are two types of overage charges. Once is when the customer buys say a certain amount of resources themselves over the limit and the other when the customer exceeds resource limits during account operation. Normally resellers would set higher prices for overages during account operation to encourage customers to buy resources in bulk, in advance. You can of course prevent customers from buying additional resources altogether by setting hard limits.
Ok. What I understand is that “Monthly” refers to the regular price the customer will have to pay for more resources. But “Extra” is the cost that he will have to pay if the exceeds all the resources he has purchased (free+monthly). Right?
- You can rename a plan by clicking on settings
Done. Thanks!
- I didn’t understand
There is a small icon with a key that says “access” that is located next to the plan name. When you click there, you get to a page that has some checkboxes and the message “If no boxes are checked, full access to this plan is granted”. What does this mean?
Thanks for your answers. I have additional question:
I have set only the base prices using the Plan creation wizard. My customer is going to pay in advance for a full year and he does not have CC or paypal. He only pay by check. How can I avoid that he be controlled by the month?. That is, I want that he won’t be disturbed with messages about the biling period for one full year. How do I do that?
Thanks Yash
P.S. I just have one hour before creating my customer’s account. Please, help me with this quickly if you can :rolleyes:
